Multifunction DAQ
How can I use low pass fillter function to correctly filter data array from DAQ?
I'm using DAQ to recieve thermocouple voltage attacted to AMUX-64T. I found powerline voltage, 50 Hz, is added to the thermocouple voltage. I'd like to eliminate it by using low pass filter function of LabVIEW. I try to connect low pass filter to "AI Read AI" directly, but I can't. How can I use low pass fillter function to correctly filter the data from DAQ? What type of filter should I use? Should I multiply the data before filtering? I need to see any example involed, if you can. I've attached "My VI.vi" file already. I would like to know where I should add LP filter. If you want any more detail, you can mail to me.
(2,625 Views)
Most people never use the low pass filter VI's for thermocouple measurements. Since you're only interested in a DC measurement, most people just oversample and average, just the way it looks like you already have your application. So I would go ahead and stick with the averaging method you are already using.
Try increasing the number of samples that you average and see if that makes a difference.
Russell
Applications Engineer
http://www.ni.com/support
(2,625 Views)
