Easiest way to connect DAQCard-1200 to BNC Input
I have a DAQCard-1200 and I'm looking to capture a waveform from a BNC input signal. I can't seem to find any cables that go along with it, so I was wondering what the simplest setup is for collecting one channel of BNC input. Do I have to buy a Ribbon Cable and connect that to a BNC Adapter Board?
Thanks for your help.
Steve Russell
(2,564 Views)
Steve,
To obtain BNC connectivity with your DAQCard-1200, you will want to use the BNC-2081 connector block. The PR50-50F cable will connect your DAQCard-1200 directly to the BNC-2081. Below is a link to the user manual for the BNC-2081:
BNC-208X Series User Manual
Good luck with your application.
Spencer S.
(2,564 Views)
