Equivalent daq
Hello.
I have a system with  DAQ NI-USB 6210  and  cDAQ NI 9217 chassis with two NI 9215 modules.
The system is fine.
Now i want to make the same aquisition system with board type DAQ, or OEM DAQ, in order to mount them in a box. I don't know the right name for it.
I just know that it exists.
I don't want PCI equivalent, because i don't want a computer. I want to build a box with DAQs, separated from laptop.
I saw years ago, such DAQ mounted on a board with screws. ( It looks like a PCB with chips, ports, pins, etc).
So, my question is: What is the equivalent board pcb DAQ for NI USB 6210 and NI 9215 module ?
Any help ?
Maybe a link ?
Thanks.
(3,641 Views)
Hi, you can find the 6210 OEM here. I would suggest using the selection menu on the right and search for cards (USB or externally powered) that match the specs of the other DAQ devices.
Alejandro C. | National Instruments
(3,616 Views)
NI USB 6211 is very good.
But what about cDAQ NI 9217 chassis with NI 9215 module  ??
9215 has simultanious channels, not aggregate.
(3,608 Views)
