How to connect DAg to ARM9?
hi all,
I want to use DAG to connect to ARM9 in order to do my senior project. So i would like to know that Is DAG able to connect to ARM9? How?
Thank you very much.
(2,956 Views)
Which DAQ product? Which ARM9 platform?
All National Instruments DAQ products are designed to work with NI-DAQmx driver software or NI-DAQmx Base driver software, neither of which support any ARM9 platform.
You may not be completely out-of-luck depending on which DAQ product you use: If your ARM9 platform has a PCI interface and is running Linux, Comedi supports a number of PCI E-Series and M-Series devices. If you want to use an NI USB-6501, a forum member created a lightweight library using libusb to talk to one. Note that both of these are from third parties and as such are completely unsupported by National Instruments.
(2,940 Views)
