Multifunction DAQ
Error -200077 occurred at DAQ Assistant
I am trying to configure an anlog output of a USB-6009 using the DAQ assistant. In timming settings, setting generation mode to continuous samples leads to the following error:
"Error -200077 occurred at DAQ Assistant
Possible Reason(s):
Requested value is not a supported value for this property. The property value may be invalid because it conflicts with another property.
Property: SampTimingType
Requested Value: Sample Clock
Possible Values: On Demand"
Is it due to the fact that USB-6009 does not spport an internal clock ?
thx
(4,186 Views)
That is correct. You can only update a single point at a time with software only timing.
(4,183 Views)
Thx a lot for quick respopnse
(4,160 Views)
