Error 200361 with multiple USB-6212 devices
I frequently see a "Onboard device memory overflow" error (code 200361).  I have several USB-6212 devices generating and sampling at the same time and connected through a hub to a single USB port.  The sample rate is 8ksps/chan and the sample count is approximately 50ks/chan.  The error started appearing when we increased the distance between the computer and the device and started using USB active extension cables.  I believe all of the USB components are USB 2.0 High Speed.  I am using the C programming interface; finite sampling; default buffer sizes; reading and writing integers.  In addition to focusing on the active extension cables, is there anything else I should try?  I want to eventually be able to run 16 channels * 8 devices simultaneously.
(3,157 Views)
Hi stesteve,
I found this article. Please take a look to it.
Best,
Carmen C.
(3,143 Views)
