Error 201388 Remains after reserving chassis
I have a new cDAQ-9188.  When running self-test on any of the installed modules I receive error 201388 (network device is not reserved for this host).  After clicking Reserve Chassis, and then running self-test this error remains.  Also, after clicking Unreserve Chassis, I get the same error.
(3,426 Views)
If you reset the chassis using the button on the chassis itself, and then try to reserve it, does the problem persist?
Jon
(3,387 Views)
I am not with the system now, so I cannot answer your question.
However, I was able to overcome the problem by launching the Reserve Chassis method from a different spot with MAX.  I was having trouble with Reserve Chassis when I had the NI cDAQ-9188 .... highlighted in the tree view and using the Reserve Chassis button in the right pane.  Reserve Chassis worked when I highlighted Network Devices in the tree view and chose Reserve Chassis by right-clicking the NI cDAQ 9188 in the right pane.
Thanks for your response.
(3,377 Views)
