Port 0 pins are outputs when I tell them to be inputs
The Port 0 pins on my USB-6341 are outputs when I tell them to be inputs.  The comparators that drive them will only work when I disconnect them from pins 1 & 2 on the USB-6341's Port 0.
I have attached the two VIs I am using.  They were written in LabVIEW 2010.  I used the DAQ Assistant and converted to NI-DAQmx Code.
What am I doing wrong?
Thanks in advance,
Jeff
(3,134 Views)
Hi Jeff,
let me ask you some further details on base of which I can give you the proper answer. How do you set your pins to be output?, are you using MAX (Measurement & Automation)? Can I ask you for schematic sketch of your circuitry? Could you please explain to me how do you measure outputs when they are set to be inputs?
Kind regards
Marek S.
(3,116 Views)
Hi, Marek
  I used the DAQ Assistant to create the monitor VI and used the Generate NI-DAQmx Code command.  I had previously defined a Virtual Channel in the Measurement and Automation Explorer (named CheckIfClosed).
  I can now read the bit.  I tracked my problem down to a misunderstanding of the Virtual Channel functionality.  I had originally defined the Virtual Channel as pointing to Port 2, Line 5 but, because Port 0 is the only digital input with a hardware buffer, I had swapped those two ports and the CheckIfClosed bit was now connected to Port 0.
  I changed the Virtual Channel definition in MAX, but the sub-VI that referenced the bit seems to only use the name as a courtesy and was still pointing to Port 2.  Just to be on the safe side, I re-defined the VI using the DAQ Assistant and the correctly-aimed Virtual Channel and it now works.
Thanks for the attempt to help,
Jeff
(3,089 Views)
