Error-88708 occurred at DAQmx create channel (AI-voltage-basic).vi:1
Error-88708 occurred at DAQmx create channel (AI-voltage-basic).vi:1 This error message occurred when I tried to open LABVIew program after the power went off and came back. Any solutions please?
(5,339 Views)
Resource not available.  What type of DAQ are you using?
The simple solution should be to reboot your computer so that the device can be found by Windows again.
(5,335 Views)
