Error -89130 occurred at DAQ Assistant
Dear friends,
I am stuck with this. Whenever I run the DAQ assistant configuration, it displays this error.
Possible Reason(s):
Device not available for routing. It is possible that the device needs to be reset or that the device is being reset.
If you are resetting the device, wait for the reset to complete.
For example, if you have used the device through Traditional NI-DAQ, you must reset the device before the requested route can be made. For SCXI devices, you must reset the communicator DAQ device. Call the Traditional NI-DAQ Device Reset VI or the Init_DA_Brds function. To reset all devices in Traditional NI-DAQ, right-click the Traditional NI-DAQ Devices folder in MAX and select Reset Driver for Traditional NI-DAQ.
I have tried the Device Reset VI, to my disappointment it also failed. (displays some error-out)
I'm running LabVIEW 7.1, DAQmx 7.1 on an IBM server. It started showing this error after a Windows XP repair, because of a system failure.
Please post your suggestions to get out of this.
Thanks.
Neeraj.
(4,947 Views)
(4,899 Views)
Thanks. Your linked helped me to solve my own similar issue.
(4,737 Views)
