Trigger AO module using PFI on cDAQ-9188
I am using a cDAQ-9188 chassis with an AO module (NI-9264).  Is it possible to configure a PFI (channel on the chassis) as a trigger input in order to sync an AO channel with the trigger?  Here is what I'm trying to do.  I need to have a channel on the AO module to switch voltages in sync with the trigger when the user "pushes a button".  So once the button is pushed, the AO channel won't change until the next trigger pulse.
Thanks for your help
Ben
(4,116 Views)
Accepted by topic author BPyke
Hello Ben
I hope you are well.  The consensus is that this is possible.  Have you attempted this yet?  If so, can you tell me what you have tried/how much progress you have made?  I recommend the following example VI:  Cont Gen Voltage Wfm-Ext Clk.vi.  Are you able to obtain any of the functionality you are looking for from this VI.  It was recommended that I show you this.  This VI can be found under Help --> Find Examples and then Hardware Input & Output --> DAQmx --> Analog Generation --> Voltage.
Please let me know how you are progressing and if you need any aspects of that example explained.  Thank you for choosing National Instruments!
Sincerely,
Greg S.
Sincerely,
Greg S.
(4,095 Views)
Thank you Greg,
That was a great help.  I didn't know how to configure the PFI port on the 9188 chassis.
Thanks Again
Ben
(4,084 Views)
Hello Ben
I'm thrilled this has worked out for you!  All the best with your endeavours and thank you for choosing National Instruments!
Sincerely,
Greg S.
Sincerely,
Greg S.
(4,074 Views)
