Multifunction DAQ
Error code 10007 when test PCI-6031E board
When I run 'Test Panel' from 'Measurement & Automation Explorer' for PCI-6031E board, I can only set AI channel to 0-7. For any channel above 7, error code 10007 appears. But the board supposes to have 32 channels in differential mode. I am using Windows 2000 and NI-DAQ 6.9.2 driver. What can I do to fix the problem? Any suggestions will be greatly appreciated.
Clei
(3,684 Views)
CHeck out the manual for the specifics on which channels are paired when in differential mode.
The "next" channel after 7 is probably going to be 16 or 32.
Ben
(3,684 Views)
Greetings,
Ben is absolutely correct. Below is a link to a KnowledgeBase with more information regarding the valid channel numbers for boards with 32 differential channels:
Why Can't I Read More Than 8 Differential Channels on My 64-Channel DAQ Board? [link removed; article no longer available]
Good luck with your application.
Spencer S.
(3,684 Views)
