Error handling message is weird.
Hello?
I'm testing if DAQmx works with an old PCI-6025E. I wrote a console program and an MFC program.
The error handler, DAQmxErrChk() works fine with the console but doesn't work with the MFC. I'm using VC++ 6.
An MFC code is
#define DAQmxErrChk(functionCall) if( DAQmxFailed(error=(functionCall)) ) goto Error; else goto Error
int CTestDialogClass::FindMyDAQLegacyDevice_With_DAQmx()
 int  error=0;
 char errBuff[2048]={'\0'};
 char devNames[256]={'\0'};
 char testDevName[256]={'\0'};
 TaskHandle taskHandle=0;
 DAQmxGetDevProductType("Dev1", testDevName, 256);
 DAQmxGetSysDevNames(devNames,256);
 m_cstringProductName = testDevName;
 m_cstringDeviceName = devNames;
 DAQmxErrChk(DAQmxCreateTask("",&taskHandle));
 //DAQmxErrChk(DAQmxStartTask(taskHandle));
Error:
 if( DAQmxFailed(error) )
  DAQmxGetExtendedErrorInfo(errBuff,2048);
 if( taskHandle!=0 ) {
  // DAQmx Stop Code
  DAQmxStopTask(taskHandle);
  DAQmxClearTask(taskHandle);
  AfxMessageBox("Error!", MB_OK, 0); //it results this automatically.
 return 0;
DAQmxErrChk() is used a lot in a console program, it works like a charm. When I run this MFC, it automatically shows Erorr! message box.
A console code is...
#include <stdio.h>
#include <Windows.h>
#include <NIDAQmx.h>
#define DATA_LEN 500
int main(void)
 int         error=0;
 float64         data[DATA_LEN];
 uInt64          bytesWritten = 0;
int i;
// Build the channel name.
char            channelName[100];
char            deviceName[100];
char            deviceNumber[10];
char            c;
 // DAQmx Configure Code
 DAQmxErrChk (DAQmxCreateTask("",&taskHandle));
 //DAQmxErrChk (DAQmxCreateAOVoltageChan(taskHandle,channelName,"",-10.0,10.0,DAQmx_Val_Volts,""));
 DAQmxCreateAOVoltageChan(taskHandle,channelName,"",-10.0,10.0,DAQmx_Val_Volts,"");
 DAQmxSetBufOutputBufSize(taskHandle, 512);
    //DAQmxErrChk (DAQmxSetBufOutputBufSize(taskHandle, 512));
    //DAQmxErrChk (DAQmxCfgSampClkTiming(taskHandle, "", 1000, DAQmx_Val_Rising, DAQmx_Val_ContSamps, 1000 ));
 DAQmxCfgSampClkTiming(taskHandle, "", 1000, DAQmx_Val_Rising, DAQmx_Val_ContSamps, 1000 );
 // DAQmx Write Code
        //DAQmxErrChk (DAQmxTaskControl(taskHandle, DAQmx_Val_Task_Commit));
  DAQmxTaskControl(taskHandle, DAQmx_Val_Task_Commit);
        //DAQmxErrChk (DAQmxGetWriteTotalSampPerChanGenerated(taskHandle,&bytesWritten));
  DAQmxGetWriteTotalSampPerChanGenerated(taskHandle,&bytesWritten);
        printf("Before write:  Bytes written: %d\n", bytesWritten);
        for (i=0; i < 5; i++)
         //DAQmxErrChk (DAQmxWriteAnalogF64(taskHandle,DATA_LEN,1,10.0,DAQmx_Val_GroupByChannel,data,NULL,NULL));
   DAQmxWriteAnalogF64(taskHandle,DATA_LEN,1,10.0,DAQmx_Val_GroupByChannel,data,NULL,NULL);
                // How much does it think we wrote?
                printf("Bytes written: %d\n", bytesWritten);
        // Get rid of the current task and create and configure a new task.
 //DAQmxErrChk (DAQmxClearTask(taskHandle));
        // Try reseting device
        //DAQmxErrChk (DAQmxResetDevice(deviceName));
  DAQmxResetDevice(deviceName);
        // Create a new task and do it all again.
 //DAQmxErrChk (DAQmxCreateTask("",&taskHandle));
 DAQmxCreateTask("",&taskHandle);
        // With this new task see how many bytes it thinks were written. Should be 0.
        printf("Second task - Before write:  Bytes written: %d\n", bytesWritten);
        // Give it some time to do the write.
        Sleep(500);
        printf("Second task - Bytes written: %d\n", bytesWritten);
Error:
  // DAQmx Stop Code
  printf("DAQmx Error: %s\n",errBuff);
 printf("End of program, press Enter key to quit\n");
 c = getchar();
 c = getchar();
  return 0;
This is an example of someone's code in this forum. This works for me. I just commented out every DAQmx functions except one to find if it causes a same problem.
So error routine is exactly same except printf() and AfxMessageBox().
DAQmxErrChk() is ONLY and EXACTLY used at the same time when creating a task.
But why are error results so different?
PS. Thanks for everytime whenever you answer.
Message Edited by anarkie on 07-23-2008 10:55 AM
Message Edited by anarkie on 07-23-2008 10:56 AM
I'm converting DAQ to DAQmx..from Parkoz.com
(3,060 Views)
Could you try running the MFC app without the DAQmxErrChk() macro and see if you get errors?  This will help us determine whether it's a problem with DAQmxErrChk().
Rod T.
(3,033 Views)
Ah....I fixed the problem. The problem was at if() condition. I used a wrong code.
Thanks.
(3,027 Views)
