What is difference of DAQ series
I want to learn difference of DAQ series for instance B,C,E, M, S, R and what is the usage of these, where we can use
Could you organize those card series
(3,125 Views)
This comparison should answer some of your questions...
(3,124 Views)
Hello Umutozkans,
I wanted to additional explanation to the link. Please notice that the C, M, S and R series are the most actual DAQ boards.
You can compare the B and E series with the M series. Those are all multiplexed DAQ boards (for the analogue inputs there is one Analog to Digital converter, a multiplexer will route the signals to the A/D converter; sample rate will be equally divided over the input channels). You will notice a better signal to noise ratio, range accuracy and sensitivity with the M series (please have a look at the detailed specifications). Often the M series has a higher sample rate and  bit accuracy. The E series is mostly available for drop in replacement.
If you compare the other PCI DAQ boards with the M series;
- S series is a simultaneous card, so a AD converter for each analog input. You will be able to set a sample range for each individual channel.
- R series is a FPGA card; you can use this with Labview FPGA to create your own hardware. Program a number of counters on the card, arrange onboard filtering, onboard protocols, PID control etc. When there isn't a solution in exsisting DAQ boards, and the solution can't be partial done in software, you may consider a FPGA card.  Please find more information at www.ni.com/fpga
- C series is a industrial range (onboard isolation) ; these modules can be used on the USB port (combining different modules in a chassis or a single module in a carrier). Isolation is one difference with most other DAQ cards, signal conditioning (cold junction compensation for thermocouple measurements (NI 9211) is another aspect.
This is a general overview from the different ranges. I hopes this makes everything a little bit more clear, I can recommend a representative to sort out which card is best for your solution.
A great starting point to select your DAQ card is www.ni.com/daq ; this is a kind of DAQ selector.
Martijn
Martijn S
NI Netherlands
(3,119 Views)
