Error in DAQThe requested memory could not be allocated Status Code:-50352
I Created two tasks for channel 0-11 for writing Data, and from 12-19 for Reading Data.
Here is the posrtion of the code:--
static TaskHandle  InputTaskHandle = 0;
 uInt16 readArray[1000];
 chkDaqErr(DAQmxCreateTask ("DaqmxInputTask ", &InputTaskHandle));
 chkDaqErr(DAQmxCreateDIChan (InputTaskHandle, "Dev1/line12:19", "", DAQmx_Val_ChanForAllLines));
 chkDaqErr(DAQmxCfgSampClkTiming (InputTaskHandle, NULL, sampleRate,DAQmx_Val_Rising, DAQmx_Val_ContSamps, (uInt64)1E9));
 chkDaqErr(DAQmxReadDigitalU16 (InputTaskHandle,numSamples, 1.0, DAQmx_Val_GroupByChannel ,
  readArray, 1000, &sampsPerChanRead, 0));
I am getting the error at this point ->DAQmxReadDigitalU16
Errorr is
Error in DAQ writing format to NI-6537->The requested memory could not be allocated.
Task Name: DaqmxInputTask
Status Code: -50352
I am attaching the code also.
Please can you tell me where its going wrong?
(3,236 Views)
Hi Molugu,
In continuous mode, the sampsPerChanToAcquire parameter of DAQmxCfgSampClkTiming is used to determine the buffer size. You are specifying 1e9 samples. If each sample is 4 bytes, that requires a 4e9 byte buffer, which is about 3.7 GB. If each sample is 2 bytes, it's still a pretty large buffer, and I don't know how much RAM you have in your PC. Try reducing sampsPerChanToAcquire.
Brad
Brad Keryan
NI R&D
(3,226 Views)
