FP-1001, FP-RTD-122, 3-wire thermistor
i have FP-1001, FP-RTD-122, both connected together, and wired 3-wire thermistor on it (inputs 3,4,20, properly)
I want to measure temperature. I have RS485-RS232 converter. Using VISA test panel, sending something to port makes FP-1001 blink NETWORK light.
Opening DAQ in LabVew... going "aquire signals -> analog signals -> temperature", and everyone i pick says i have "no supported devices".
If there's a way to: how can i solve that? Do i 300% need FP-1000? 😕
(4,010 Views)
Accepted by wattss
Hi wattss,
Using filedpoint is simple, however it is not as simple as using our more modern devices.
The FP-1001 can be connected directly to a PC with RS485, as seen in the FP-1001 datasheet here:
http://www.ni.com/pdf/products/us/4dio541_543.pdf
1. You need to see the RS485 port in MAX. We do have problems with low-end serial adapters from time to time, please use NI products, such as the NI USB-485, they implement full hardware support for the serial port.
2. Set up the hardware as described in the FP-1000/1001 FieldPoint Quick Start Guide.
3. You will need the FieldPoint drivers installed.
4. You will need to Add the FieldPoint to MAX: right-click and add a "FieldPoint Serial" to the "My System / Devices and Interfaces" by discovering the serial port.
5. You will need to configure the Thermistor nodes on the FP-RTD-122 (just explore the menus / toolbars / right-click items under the FP-1001 node under Devices and Interfaces in MAX).
6. At this point you sohould be able to see the FeildPoint device in MAX under the "Data Neighborhood" - this is where you can actually see the data from the FP-1001, and test if it works.
7. You will need to "Save" the hardware configuration you created to the FP-1001 itself: Click "Save" under "Devices and Interfaces". You should also save the final configuration as an .iak file (from "Data Neighborhood")
Now, you can start using the FP-1001 from LabVIEW.
It has been some time since I used FP, so you might have to get creative with some of the steps above.
Please let me know if you need further help.
Best Regartds,
Tamás Simon
Best Regards,
T Simon
Certified LabVIEW Developer - Certified TestStand Architect
(3,989 Views)
"1. You need to see the RS485 port in MAX. We do have problems with low-end serial adapters from time to time, please use NI products, such as the NI USB-485, they implement full hardware support for the serial port."
As i have also mitsubishi's PLC at home, i have FX-485PC-IF adapter (RS232-RS485), and using with mitsubishi's PLCs, i had no faults yet. Also, using Visa TP (test panel) - it seems to send commands properly.
I've installed drivers now, and will try it later today - currently its 00.15AM here - and will report up later.
(3,977 Views)
Hi, I'm back,
I've managed to see data in MAX.
As it's visibile in attachment, there is no supported module in LabView (2011, v11.0).
What am i doing wrong? I've opened new VI, left-clicked Block diagram, input -> DAQ Assist.
I place it on block diagram, Acquire signals, Analog signals, Temperature, RTD. I click on RTD and then i get "no supported devices found" error/notice.
I get this wether MAX is working behind, collecting data or not, or if its not working. I've saved all configurations in MAX before.
I think i am doing something wrong, but can't find it where.
I'm looking forward to read you soon,
Regards, Erik
(3,966 Views)
Hi Erik,
The reason you can not use DAQ assist with FieldPoint is the same why you could not see the FP device in MAX earlier:
FieldPoints do not use the DAQmx driver package.
Fortunalety, you have already installed the FieldPoint drivers, so you should be able to see the FieldPoint palette in LabVIEW:
For further programming help, I recommend searching the NI DeveloperZone for tutorials and the NI Example Finder for example code - most of it is from 2006-2007 (LabVIEW 7), but so is FieldPoint, so you will find something still usefull.
The concept of using the FieldPoint VI-s is very similar to every other rescource handling in LabVIEW - If you have successfully programmed DAQmx before, then I am confident that using FieldPoint will not be a problem.
Best Regards,
Tamás Simon
Best Regards,
T Simon
(3,949 Views)
Hi Simon,
Thanks for fast reply. I was really looking for a "kickstarter" to gain my data from, now everything is running out like charm. App is expanding 🙂
Thanks again for help,
regards, Erik
(3,941 Views)
