‎01-04-2007 12:02 PM
So, the problem goes away in a different PXI-1042 chassis. The PXI-1042 backplane is entirely passive from a PCI standpoint. It is just copper wires and doesn't have many components to break. The PCI bus itself is a very robust and mature technology.
Speculation about what could be going wrong:
I am assuming that the peripherals appear to be working, but just not as fast as in the other chassis. I mean, the test gets good data, just much more slowly than in the 'good' chassis.
Jason
PXI Hardware Engineer
‎01-05-2007 11:56 AM
I just wanted to chime in on this. It is VERY important that you disable USB from the BIOS. With LV 8.2 there are actually 2 USB settings. The one in the BIOS disables legacy OS support, and the one in the ini enables/disables the Pharlap native USB driver. The MOST important one to disable is the one in the BIOS. It is a little confusing I know. What it breaks down to is actually a 2x2 matrix. Setting the ini setting to True automatically disables the one in the BIOS (which is good), but setting the ini setting to False (again this is the Plap driver not the OS USB support) doesn't have any affect on the BIOS. If you want MAXIMUM performance you need to disable the bios AND set the ini flag to false. In practice though, for the rates you a looking at settng the ini entry to TRUE should be sufficieint.
Hope this helps
StuartG
‎01-05-2007 01:29 PM
‎01-08-2007 11:14 AM
