Fastest acquisition possible in C
I am using a PCIe 6341 board and coding under visual c++ 2010. I need to do an analog acquisition of 10 points at 500kHz every 200µs. In order to be fast, I permit the card to overwrite the buffer and take the last 10 points written in the buffer. Unfortunately, the time to take the data is of 10ms which is too slow for me who need to read the data every 0.2ms. What do I do wrong ?
My code is :
#include "stdio.h"
#include "NIDAQmx.h"
#include <time.h>
#define DAQmxErrChk(functionCall) if( DAQmxFailed(error=(functionCall)) ) goto Error; else
#define nb_point 10
#define frequence 500000
int main(void)
    int32       error=0;
    TaskHandle  taskHandle=0;
    int32       read;
    float64     data[nb_point];
    char        errBuff[2048]={'\0'};
    int64        samplesToAcquire=100000 ;
    int            cpt ;
    // essai pour mesure du temps
    int
        temps_initial,
        temps_final;
    float
        temps_cpu;
    // DAQmx Configure Code
    DAQmxErrChk (DAQmxCreateTask("",&taskHandle));
    DAQmxErrChk (DAQmxCreateAIVoltageChan(taskHandle,"Dev1/ai0","",DAQmx_Val_Cfg_Default,-10.0,10.0,DAQmx_Val_Volts,NULL));
    DAQmxErrChk (DAQmxCfgSampClkTiming(taskHandle,"",frequence,DAQmx_Val_Rising,DAQmx_Val_ContSamps,samplesToAcquire));
    DAQmxErrChk (DAQmxSetReadRelativeTo(taskHandle,DAQmx_Val_MostRecentSamp));
    DAQmxErrChk (DAQmxSetReadOffset(taskHandle,nb_point));
    // debut de mesure avant le lancement de la tache
    printf("Parti?\n");
    getchar();
    // DAQmx Start Code
    DAQmxErrChk (DAQmxStartTask(taskHandle));
    // DAQmx Read Code
    for ( cpt = 0 ; cpt <11 ; cpt++ )
        temps_initial = clock ();
        DAQmxErrChk (DAQmxReadAnalogF64(taskHandle,nb_point,10.0,DAQmx_Val_GroupByChannel,data,nb_point,&read,NULL));
        // fin de mesure du temps
        temps_final = clock ();
        temps_cpu = ((float)temps_final - temps_initial)/CLOCKS_PER_SEC;
        printf("Temps d execution : %f\n",temps_cpu);
        printf("Acquired %d points\n",read);
Error:
    if( DAQmxFailed(error) )
        DAQmxGetExtendedErrorInfo(errBuff,2048);
    if( taskHandle!=0 )  {
        // DAQmx Stop Code
        DAQmxStopTask(taskHandle);
        DAQmxClearTask(taskHandle);
        printf("DAQmx Error: %s\n",errBuff);
    printf("End of program, press Enter key to quit\n");
    getchar();
    return 0;
Thanks a lot for your help !!!! I am quite desesperate to solve this problem !!!!
(3,139 Views)
duplicate
Samuel G. | GEMESIS
Certified LabVIEW Architect
Certified TestStand Developer
GEMESIS.EU
(3,091 Views)
Je pense que si la reactvite et l efficacite de vos servives avaient plus grande je n aurai pas eu a poster sur le forum 3 fois la meme question.
Merci d avoir apporte tant de reponses a mon probleme
(3,071 Views)
