Firmware for NI 9237
I'm using NI-9237
I received an error msg
"201340 occurred at DAQmx Perform Bridge Offset Nulling Calibration.vi. Possible reason(s): Firmware on the device is out of date." Firmware needed to be updated.
I went to NI MAX, Update Firmware, it says the current firmware is 1.2.0f0
I googled, could not find firmware for 9237. I used the following searches: "9237 firmware", "NI9237fw", "NI9237fw.cfg", etc.
Please help
(2,999 Views)
Accepted by ngthai
What chassis or carrier do you have the 9237 in? The NI 9237 module itself doesn't have firmware.
Is it in an ENET-9163 or WLS-9163 carrier? On those devices we present the carrier+module as a combined unit in MAX, which might relate to the confusion. In that case, WLS-9163/ENET-9163 Firmware 2.0.1 is the most recent version, and is compatible with NI-DAQmx 9.3 and later.
(2,969 Views)
