Firmware for cDAQ 9185
Here I can find firmware for cDAQ 9185.
The most recent one (visible as the default in the dropdown list) seems to be 18.1.0 (release date July 3rd, 2018).
But in the dropdown list there is firmware 18.6.0 (the release number is higher), with release date May 17th, 2018.
Which is the newest firmware for cDAQ 9185?
Vix
Using LV from 7
Using LW/CVI from 6.0
(2,441 Views)
Dear Vix,
I would suggest installing DAQmx version 19.1 or later, and get the latest firmware for your device from here. According to the link you shared, the latest version should be 18.1.0, but it is better to get the firmware from NI MAX or your browser.
You can find an instruction to update latest firmware version by the following link: Firmware Information for NI CompactDAQ Network Chassis.
instructions are located under Upgrading Your Firmware Version.
(2,406 Views)
Hello Arkadi,
the cDAQ chassis has been already delivered to customer site and it's connected to a PC which cannot have access to internet.
So I need to download it from my PC and transfer the file to the customer.
On my PC I have DAQmx 20.0 installed.
In which folder can I find the firmware?
Vix
Using LV from 7
(2,383 Views)
Accepted by vix
On my system
  • 9189: C:\Program Files (x86)\National Instruments\Shared\Firmware\DAQmx Device\78B9
  • 9185: C:\Program Files (x86)\National Instruments\Shared\Firmware\DAQmx Device\78C7
(2,355 Views)
