Multifunction DAQ
GEtting started with NI cDAQ 9172 with NI9477 and NI9426
I quiet fresh on labview and I just get a NI9172 with a NI9477 and NI9426. I definitely need an example to start learning the use of these devices. Is there any  .vi file that would show me how read and write these devices?
Thank you,
Olivier
(3,417 Views)
Accepted by OD
Hi Oliver,
Both of these modules use the DAQmx driver and are programmed like the rest of the DAQmx devices.  There are examples installed with the driver that can be found in LabVIEW.  From LabVIEW select Help>>Find Examples to open NI Example Finder, then expand the Hardware Input and Output>>DAQmx>>Digital Generation or Digital Measurements
Hope this helps!
h_baker
Applications Engineer
(3,392 Views)
