Generating pulses in DAQ-USB-6259
Hi
Am student working on a stimulation project. For this, i need to generate a single pulse or sometimes pulse train. The following are the requirements
*Need to control the polarity of the pulse (High pulse or low pulse)
*Need to control the timing of the pulse i.e. pulse width
*Need to have amplitude control ( i.e. vary the amplitude when required)
I am using a NI-DAQ-USB 6259, which has 4 Analog outputs. I intend to use one of the outputs for the same.
I came across this example but i am not able to understand its controls.
 http://zone.ni.com/devzone/cda/epd/p/id/1621
I dont know much about labview and a novice in Labview. Could not get much idea from the block-diagram in the above given VI.
Please help me with respect to this. Will the above given VI satisfy my requirements or should i modify it??
K.S.Padmanabhan
(3,231 Views)
I don't think anyone will help you, if you don't help yourself.
You should start from LabVIEW tutorial: http://zone.ni.com/devzone/cda/tut/p/id/7466
Good luck!
(3,199 Views)
Thanks for the tutorial link, KateB.
I understand the need for familiarising myself with labview environment first.Humm... a bit short of time because this requirement was added late. Thats the reason i was just searching for VI's in net that would fit the requirement directly.
Anyway, now that i have got a link for the tutorials, would definitely go through these and come back in case of any queries.
(3,196 Views)
