Get_DAQ_Device_Info() run-time error
 I am using Get_DAQ_Device_info() in a cvi application. I created a stand-alone executable using cvi 7.0. And when I ran the application, I am getting a run-time error which says "runtime error R6025 - pure virtual function call " . If i remove the function call Get_DAQ_Device_Info() from the program, I don't get the run-time error. Can anyone pls help me on this issue...
(2,947 Views)
Thank you for posting to the NI forums.  For your convenience and the completeness of our discussion forums, please use the following forum to post all further information.
Get_DAQ_Device_Info run-time error
Thanks!
Ed W.
(2,935 Views)
