acquire 14 samples from compact fieldpoint at different sample rate
I am working on an application that will acquire 14 channels from the mA module, so it outputs an array of dbls.  The user wants to be able to configure each channel to have its own acuire rate.  We are talking 30 sec/sample, up to a couple of minutes, so it is not a fast acquisition.
The problem is that the fieldpoint only outputs one array of all the channels and the sameples could be 45 sec/sample, so it is hard to come up with a common point.
I am looking on some advice on the best way to accomplish this.  Some ideas I came up with:
-Put the data into a shared variable at a much faster rate (1-5 sec/sample) and then a number of parallel while loops that have independent wait_ms clocks or timed loops and each iteration pull from the variable.  But this would get tedious with 14 loops, and there is the possibilty of more channels in the future.
- Tell the user that he can set only one rate for all the sensors (the lazy waySmiley Tongue)
- Multiple loops that read the data (using the cFP vis) at the selected interval (possible errors if 2 reads occur at the same time???)
Thanks for the input.
Kenny
Kenny
(2,816 Views)
Kenny,
After reading what you are trying to accomplish I was getting ready to suggest what you yourself have suggested as your 3rd option.
Using the FieldPoint read VIs in separate loops that each run at the desired rate would be the approach I would take.
Simon H
http://www.ni.com/support/
(2,809 Views)
