Hi! How could I use the current analog output in PXI-6704 to get O mA as minimum output? In specifications it is said that the range value for the current is from 0.1 to 20,2 mA. I need for my application to get exactly O mA (so, open circuit) as lower limit. How could I get the null current for a floating load (no return ground) from the CVI control software? I have thought as an alternative to disable from software the analog output and hope not to get current there. So disable to get null current and enable again to output the desired current when neccesary. Do you know a more formal solution? Thanks in advance.
