RS-232 speed and level config. in 8432/4 card
Hi! I would like to know if it is possible to configure the communication speed of the RS-232 protocol signals when using the PXI-8432/4 from a Labwindows/CVI application in order to establish a non-standard speed as, for example, 50 kbps.
Second question. The signal levels of the 8432 card is +25V and -25V. Is there any way to configure the RS-232 range signals to +5V to 0 V?
Thank you!
Message 1 of 1
(3,080 Views)
