Gpib usb vc++
I have bought a new USB-GPIB controller. It works well, when communicating with listening instruments by your software-Measurement and Automation. However, when we try to use Visual C net to compile your example (4882query.c), after include ni488.h, it gives out the error information:
Error LNK2020: Unresolved token (ibsta).
Error LNK2020: Unresolved token(ibcntl).
Error LNK2020: Unresolved token(iberr).
3 unresolved externals
Please help me.
(4,095 Views)
Hi I dont know,
What version of Visual Studio/Measurment Studio are you using.
The USB device will operate in the same way as a PCI GPIB card.
regards
Seamus
(4,067 Views)
Hi "I Dont Know"
I have compiled 4882query.c using Visual Studio 2005 and Measurement Studio.
I created a Win32 Project and under Visual C++ and  deselected "Precompiled header"
I then removed the files that were added by the wizard from the solution viewer. and added 4882query.c to the source files section.
I then added ni488.h to the header files section and added gpib-32.obj to the resource files section
I was then able to compile the program and get the identity of the instrument connected to my GPIB-USB-B
Regards
JamesC
NIUK and Ireland
(4,058 Views)
I have tried to do the same for the query example program compilation, but still have the linker problem.
I use Visual Studio 9.0 Express, is it compatible with the program ?
(3,524 Views)
