What gear for VAWT maglev wind turbine + solar system development & monitoring
Apologies if my question is lame but I do value others' opinions and not rely on marketing advertisments which turn to be overstating capabilities these days.
I am thinking about building a home self-depended system. The project's scope is to construct a 2kW VAWT maglev wind turbine and 1kW mono solar panels. The turbine would be built from the ground and therefore adequate test equipemnt would be required during development as well as consequent output and performance monitoring when finished.
Woud you recommend a suitable equipment from NI or any other like campbell sci? Any experience in using them for similar application/s?
Many thanks in advance, David
Message 1 of 1
(3,430 Views)
