05-27-2008 08:21 AM
05-28-2008 10:15 PM
05-29-2008 02:58 PM
Thanks for the reply.
You are correct in what i am trying to accomplish. I am still looking for something that shows the pinouts from the CB-50LP to the USB 6221.
05-30-2008
09:19 AM
- last edited on
02-24-2025
09:07 PM
by
Content Cleaner
Hello adam12,
Thanks for your post back. For the pinouts of the USB 6221 take a look at the link below. It is a .pdf document that shows the pinouts for all versions of the USB 6221.
NI 622x User Manual
As for the CB-50LP, it shows on the deminsions drawing that the pin assignments are labled on the connector block. So pin 1,2,49 and 50 should be indicated on the board its self and the numbers incroment accordingly. Below is the deminsions drawing for the CB-50LP.
Now nowing the pin assignments this will allow you to wire the signals accordingly to the USB-6221 from your Gray Hill 24 Channel I/O board. Please post back if you have any other questions.
Corby_B
06-26-2008 10:53 AM
06-27-2008
05:10 PM
- last edited on
02-24-2025
09:08 PM
by
Content Cleaner
Thanks for the post,
I believe its not documented so well on the USB version because an OEM version is sold that is very similar internally to the USB-6221 that you are using. 🙂
That would also be a great product suggestion
Product Suggestion Center
Post back if you have any questions
