HOW CAN I GET NI-OPC SERVER
DEAR SIR,
I HAVE ONE NI USB-6008, AND I WANT ACCESS THIS UNIT BY THIRD PARTY SOFTWARE,
WE CAN ACCESS THIS DIVICE THROUGH OPC SERVER, BUT THIS DIVICE IS NOT SHOWING IN THE OPC SOFTWARE.
SO PLEASE LET ME KNOW, IS IT REQUIRE NI-OPC SERVER OR ANY DRIVER?
THANKS,
FOR SAIESH TECHNOLOGIES PVT LTD
ABHAY AGRAWAL
(3,524 Views)
Hi Abhay,
What third party software are you using to access the NI USB-6008? There are DAQmx assemblies/dlls that can be used to connect to our DAQ devices other than through LabVIEW. You mentioned that you can see it in the OPC Server and not in the OPC Software. Which OPC Software is this?
I would suggest by downloading the Server Explorer and also following the steps provided in the following DeveloperZone Document. Hope this helps.
Message Edited by Nitin T on 12-18-2007 02:19 PM
(3,496 Views)
Hi Guys-
Nitin's links actually point to information about the NI-DAQ (i.e. Traditional NI-DAQ) OPC Server.  This will not be useful for use with the USB-6008 as that device is only supported by NI-DAQmx.  Instead, you should check the information in this KnowledgeBase entry.  Specifically, the section about using "NI-DAQmx OPC with a generic OPC client".  You must create global virtual channels in Measurement and Automation Explorer (MAX) in order to monitor your device's AI channels remotely via OPC.
Hopefully this helps-
Tom W
(3,479 Views)
