HOW TO PASSWORD PROTECT A DAQ FOR OEM APP?
Hello.
I am developing an OEM application with a USB6216 DAQ and I am wondering how to password protect it or block it so when I connect it to the computer, only my software stand-alone application developed in Labview can detect it, meaning I dont want it to be seen in the MAX or any other application. How can this be done? I have already seen that the VIs (software) can be password protected, but what about the DAQs (hardware)?
Thank you.
Sincerely
JSL
(2,847 Views)
Hi JSL
One way could be creating a VI that opens the reference to a specific hardware you want to protect and saving the reference to a global variable. That VI must run once and when windows starts. If someone wants to use the resource, he will receive a message telling him that the resource is being used; if you want to use it, just call the global variable.
There is no a particular tool that permits to protect our hardware with password.
Best Regards
Coamín Cruz
AE México
Hola JSL
Una manera podría ser creando un VI que abra la referencia al software en específico que deseas proteger y almacenar la referencia en una variable global. Dicho VI deberá correr una sola vez y que sea cuando arranque Windows.  Si alguien desea utilizar el recurso, el recibirá un mensaje avisándole que el recurso está en uso; si tú lo deseas usar, solo manda llamar a la variable global.
No existe una herramienta en particular que permita proteger a nuestro hardware con contraseña.
Saludos
También damos soporte en español si lo prefieres.
Coamín Cruz
AE México
(2,756 Views)
