Multifunction DAQ
Help with Female and Male on SCH68-68-EPM and SH68-68-EP Cables
For the SHC68-68 cable, I was wondering if it is a female or male VHDCI that is plugging into the module. Also, for the SH68-68, is the module side the female or male? I would like these to match as I am replacing somethings that need a VHDCI and a SCSI. However, I need the genders to match on both sides for these two cables.
Thank you!
(811 Views)
Accepted by k_jonas
The EP and EPM cables are interchangeable.
For SHC68-68-EPM, it has a male VHDCI connector at the module side. Reference: 68-Pin VHDCI Cables : DAQ Multifunction I/O Cable Guide
For SH68-68-EP, it has a female SCSI connector at the module side. Reference: 68-Pin SCSI Cables : DAQ Multifunction I/O Cable Guide
https://tmesystems.net/
(785 Views)
