High impedence probe
I have a PCI-6110 card with a BNC-2110 connector block. I need to find a passive probe for attenuating the input voltage. What can I use? I tried Tektronik 6138A (10X) but the impedance is mismatched. Do you know of any probe that will work for sure and/or the mismatch will be within the calibration range of the probe itself?
Federico
(3,036 Views)
Hi Frederico,
National Instruments does sell a small variety of probes.  Here is a link to the data sheet for our offerings for High Speed Digitizer probes.  The SP200B has a switchable attenuation of 1X and 10X.  It connects via BNC and we offer 50ohm BNC cables for probe compensation as well.
Hope that helps...
Nicholas B, National Instruments
(3,024 Views)
