How I can program adquisition mode (single or differential) when use scan_start?
I´m using a 6062E DAQ with Borland C++ Builder. I´m getting data with scan_start function in diff mode, but I don´t know how to set single or diff mode for these DAQ. Someone know how to set these parameters? Which function to use? Thanks.
(3,243 Views)
Hi egatjens,
    With the traditional daq drivers you can use the AI_Configure function to set the inputmode for the analog input channels. Full documentation of this function and how to use it can be found in the Traditional NI-DAQ C Reference Help.  This should have been installed along with your NI-DAQ drivers. It can be found under Start»Programs»National Instruments»NI-DAQ»Traditional NI-DAQ Reference Help or at <National Instruments Install Path>\NI-DAQ\docs\nidaqpc.chm
I hope this helps.
Nathan
Nathan
NI Chief Hardware Engineer
(3,214 Views)
