Home
Community
Discussion Forums
Most Active Hardware Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
BNC-2090
BNC-2090
小龜
Member
12-20-2007
06:41 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
我所使用的是NI PCI-6221 接線盒是用 BNC-2090 及SCB-68 程式是LV7.X LV程式有很多訊號輸入的方格 平常沒有用時是將接線孔關起來的 也就是插上迴紋針 現在如果要打開接線孔 讓訊號輸入 應該在LV程式哪邊修改呢 因為是套裝軟體還不太會使用 請各位先進教我一下
0
Kudos
Message
1
of 2
(3,328 Views)
Reply
回應: BNC-2090
Ethan_Niu
Member
12-20-2007
08:10 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
您好:
如果是初學者的話,可以先嘗試使用NI-DAQmx 驅動程式所附的 signal express試試看,在擷取通道設定的地方,選擇多個通道做訊號擷取(可用鍵盤的ctrl點選多個通道),須視您硬體上的接線而定,或者是您可以用Measurement and Automation Explorer 軟體中的test panel 看看某個硬體通道使否有訊號進來,謝謝。
Application Engineer
Ethan Niu
0
Kudos
Message
2
of 2
(3,303 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
