10-08-2008 03:07 PM
10-09-2008
08:49 PM
- last edited on
04-30-2024
08:39 AM
by
Content Cleaner
Hi AEI_JR,
You can control your SCXI with the PCI-6221, but in order to do so you will need to use an SCXI 1349 adapter which will allow you to connect your DAQ device to the SCXI controlling module. As far as the analog output, you should take a look at the SCXI 1180. This is a feedthough module that will give you access to the unused lines from your DAQ card. You would be interested in the DAC0OUT and DAC1OUT lines.
SCXI-1180
https://www.ni.com/en-us/support/model.scxi-1180.html
10-10-2008 06:57 AM
Steve,
Thanks. That's exactly what I needed.
