Home
Community
Discussion Forums
Most Active Hardware Boards
Multifunction DAQ
Topic
Multifunction DAQ
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
How can I call NI-DAQmx with Borland Builder C++?
Begos
Member
01-23-2005
09:40 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
I don't know if I can use NI-DAQmx with Borland Builder C++.
If yes How can I?
I cannot use traditional NI-DAQ because when I run program linked with them I have a PC crash.
Thank You
Begos
0
Kudos
Message
1
of 2
(3,038 Views)
Reply
Re: How can I call NI-DAQmx with Borland Builder C++?
Castel
Member
01-25-2005
03:02 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
someone has already answer your question:
http://forums.ni.com/ni/board/message?board.id=231&message.id=2989
If you have installed NI-DAQ driver in your PC, you can find examples exploring C:\Program Files\National Instruments\NI-DAQ\Examples\DAQmx ANSI C
You should avoid posting the same question in many threads.
Regards
MarcoC
0
Kudos
Message
2
of 2
(3,029 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
