Multifunction DAQ
How can I customize the TABLE control/indicator as the same table in the LabWindows CVI or the DBgrid of the Borland Delphi?
I need to customize the TABLE control/indicator as the same table in the LabWindows CVI or the DBgrid of the Borland Delphi. Where can I modify the color of the Column Headers and the Row Headers.
Cleber
(3,273 Views)
I'm not quite sure if I understand your question, but if you just want to change the color of the column and row headers on your CVI User Interface, then open the uir file in your UI Editor and use the Paint tool to statically color the headers.
Jeremy L.
(3,255 Views)
I made my question wrongly. Really I would like to customize the table control of Labview as de same shape of table in the CVI...
But the help is not necessary. I had discovered how to do this ...
Thanks a milion...
Cleber
(3,251 Views)
