How can I find examples for C# handling external trigger
I have previously asked this question. And couldn't find an answer. I have the USB-6341 board and NI-DAQmx driver.
I'm not using LabView but using C# only. Most of the examples ni.com is with LabView.
I just need a short example implantation with C# for the following scenario:
When one of the external trigger input of the board receives a rising edge one of the analog output will output a certain voltage ect. How that done in C#? This is like event handling.  A short example would help a lot. I cannot find any examples and stuck in the middle of a project. I really need an example code.
Message 1 of 1
(1,188 Views)
