The missing functions in DAQmx base
In DAQmx base,
DAQmx_Val_Acquired_Into_Buffer is not exists.
(I confirmed with NIDAQmxBase.h).
Is there any way to use the function or similar alternative?
If any alternative of 'DAQmx_Val_Acquired_Into_Buffer' exists, I should use that.
(for using callback as below.)
class CallbackTask(Task):
def __init__(self):
Task.__init__(self)
self.data = zeros(1000)
self.a = []
self.CreateAIVoltageChan("Dev1/ai0","",DAQmx_Val_RSE,-10.0,10.0,DAQmx_Val_Volts,None)
self.CfgSampClkTiming("",10000.0,DAQmx_Val_Rising,DAQmx_Val_ContSamps,1000)
self.AutoRegisterEveryNSamplesEvent(DAQmx_Val_Acquired_Into_Buffer,1000,0)
self.AutoRegisterDoneEvent(0)
def EveryNCallback(self):
read = int32()
self.ReadAnalogF64(1000,10.0,DAQmx_Val_GroupByScanNumber,self.data,1000,byref(read),None)
self.a.extend(self.data.tolist())
print(self.data[0])
return 0 # The function should return an integer
def DoneCallback(self, status):
print("Status",status.value)
(1,796 Views)
I could not find a function that performs the same of similar task. The function is missing in your DAQmx, correct? You can try reinstalling the software and see if the function appears or not.
(1,646 Views)
