How can I generate a single pulse in a digital output (not a PFI) without using the counter.
Can someone help me to generate a single pulse in a digital output (not a PFI) of the PCI6251 board without using its counters?
Message 1 of 12
(5,057 Views)
What kind of pulse width are you looking for and how accurately do you need to control pulse width?
Message 2 of 12
(5,037 Views)
The pulse width must be 80ms +/-  1%.
Message 3 of 12
(5,035 Views)
Using software timing, you won't be able to count on hitting your target pulse time within 1% (less than a msec in this case).  You would have to use "correleated DIO" with one of the lines from port 0.
This type of hardware-timed DO task cannot generate its own sample clock however -- it needs to borrow one from another task or from an external source.  What other tasks are running on your multifunction board in this app?  Maybe you can borrow one of their clocks...
-Kevin P.
Message 4 of 12
(5,023 Views)
Kevin is right about software timing.  I think I would consider creating a task to output a digital 1D array or waveform and let the task use a clock in the DAQ hardware.  How critical is the timing of when the pulse starts/happens?
Message 5 of 12
(5,016 Views)
Hi Centerbolt
I already created a task to output a digital 1D array or waveform, but the pulse do not appeared in the terminal.  Could you see some problem in the attached code bellow?
Public Function GFUNC_booCreateDOPulse() As Boolean
    Dim LlngTaskHandle As Long
    Dim LbytSamples(0 to 80 * 3 - 1) As Byte
    Dim LlngSamplesCounter As Long
    Dim LlngSignalLevel As Long
    Dim LlngDummy As Long
On Error GoTo GFUNC_booCreateDOPulseErr
   GFUNC_booCreateDOPulse = False
   ' Create the sample data (80 samples in low level + 80 samples in high level + 80 samples in low level)
   LlngSignalLevel = 0
  For LlngSamplesCounter = 0 To (80 * 3) - 1
      ' Invert the polarity each 80 samples
     If  (LlngSamplesCounter Mod 80 = 0) Then
         If (LlngSignalLevel = 0) Then
            LlngSignalLevel = 1
       Else
           LlngSignalLevel = 0
        End If
    End If
    LbytSamples(LlngSamplesCounter) = LlngSignalLevel
  Next LlngSamplesCounter
   ' Create a task
   If (DAQmxCreateTask("", LlngTaskHandle) >= 0) Then
      ' Create the digital output channel
      If (DAQmxCreateDOChan(LlngTaskHandle, "/Dev1/P0.3", "", DAQmx_Val_ChanForAllLines) >= 0) Then
        ' Create the timming: sample rate 1000S/s,  # Samples = 3 * 80
         If (DAQmxCfgSampClkTiming(LlngTaskHandle, "20MHzTimebase", 1000, DAQmx_Val_Rising, DAQmx_Val_AcquisitionType_FiniteSamps, 80 * 3)>= 0) Then
            ' Write the SAMPLES
             If (DAQmxWriteDigitalLines(LlngTaskHandle, LlngPulseWidth * 3, True, 3, DAQmx_Val_GroupByScanNumber, LbytSamples(0), LlngDummy, ByVal 0) >= 0) Then
                 If ( DAQmxWaitUntilTaskDone(LlngTaskHandle, 3) >= 0) Then
                      If (DAQmxClearTask(LlngTaskHandle) >= 0) Then
                             ' End of pulse generation
Message 6 of 12
(4,989 Views)
Sorry, I don't program using text based entry.  Perhaps someone with experience can look at your code and find the problem.
Message 7 of 12
(4,977 Views)
I'd venture that the problem is in the line containing:
DAQmxCfgSampClkTiming(LlngTaskHandle, "20MHzTimebase", ...
Digital tasks can't derive their sample clocks directly from any of the onboard clocks.  They can only borrow from another task or some external signal. Possible sources on an M-series board are the the sample clock from an AI or AO task, the output from a counter pulse train task. or a PFI pin that is externally wired to a TTL frequency source.
-Kevin P.
Message 8 of 12
(4,968 Views)
Hi NDBorrego,
"/Dev1/P0.3" isn't a valid DAQmx physical channel string, so DAQmxCreateDOChan is probably returning an error which your program isn't reporting. DAQmx terminals start with a leading slash but DAQmx physical channels do not, and the software uses "port0/line3" to represent P0.3. Try "Dev1/port0/line3" instead.
"/Dev1/20MHzTimebase" may sort of work as a DO sample clock but it exceeds the board's DIO specifications because its frequency is 20 MHz. For the clocked DIO on M Series, the rate parameter to DAQmxCfgSampClkTiming tells DAQmx what frequency the clock is running at. By passing 1000 to DAQmxCfgSampClkTiming you are telling DAQmx that the 20 MHz timebase is running at 1000 Hz (which it is not). I think that DAQmx will error if you set the sample clock source to 20MHzTimebase and you set the sample clock rate to anything other than 20000000.
If you want a DIO sample clock that doesn't consume a general purpose counter, you can create a continuous CO pulse train task on the physical channel "Dev1/freqout" and then specify "/Dev1/FrequencyOutput" for your DO sample clock. The frequency output counter is a very limited 4-bit counter that can only generate continuous pulse trains, but it's useful as a DIO sample clock.
Brad
Message Edited by Brad K on 10-26-2007 07:29 PM
Brad Keryan
NI R&D
Message 9 of 12
(4,960 Views)
Minor correction to my last post: the error check I mentioned (when SampClk.src== 20MHzTimebase and SampClk.Rate != 20000000) only happens for AI. With AO or DIO, I get an underflow error as soon as I start the task, not "Sample Clock Rate must match the frequency of the internal timebase specified as the Sample Clock Source".
Brad
Brad Keryan
NI R&D
Message 10 of 12
(4,953 Views)
