How can I get my Daqcard 6036E to show up under the legacy folder in MAX
My Daqcard only shows up under NI-DAQmax, and I do not even have a NI-DAQ Legacy folder using Windows 7.
NI instructions of removing the card, removing the NI-DAQ, Installing NI-DAQ, and re-installing the card has not worked.
(4,426 Views)
Did you install the traditional DAQ driver? It only works for 32 bit. You should be moving to DAQmx in any case.
(4,421 Views)
Thanks for your input, I use DAQmx for everything new, but converting old seldom used VI's has little priority.
Yes, I had installed the Traditional NI-DAQ 7.5 with the hardware installed with no luck,  I then found an application note that had me remove the hardware (physically), remove the Traditional driver, re-install the traditional driver, and then insert the hardware.  Something like six reboots later system look the same in MAX, that being no Traditional device folder.
(4,415 Views)
Does it show up in the Windows device manager?
(4,392 Views)
Thanks for the help.  Yes, it shows up in Windows device manager and in MAX devices and interface tab
(4,386 Views)
