03-09-2009 04:51 PM
I have been programming into a EEPROM of an accelerometer using TEDS via NI-9233 & one-wire.. I've been using some NI drivers, and the SCXI-1314T library to do what I need.. but the SCXI-1314T library gives me a error about my TEDS structure. Specifically there's 2 bits that are requried to be set to 1 or else it will give me a conformity error.
Reason for going away from the standard TEDS template is due to the # bits available for the serial#. I need a larger # to conform the companies serial # so it requred me to add bits to the serial #, shifting all the bit down. Any case I've successfully use the SCXI-1314T library drivers, but since the values shifted, there are 2 bits that will cause a error when savig if they were set to zero. Is there a way to program the EEPORM memory using the NI-9233?
I would like to use something similiar to the "DAQmx Write TEDS Data.vi".
03-10-2009 01:54 PM
Hi Sidster,
This thread may be of some assistance.
David
