How can I split up signals from the Ni 9203 to create multiple graphs?
Hi I have a labview program running, reading on a cdaq 9174 on a 9211 and a 9203 unit. The 9211 unit measures 4 temperatures and shows all of them in the same graph, the same with the 9203, how can I split up a signal from the 9203 and show only channel 0 on one graph and channel 1 in another graph. I`m posting the .vi.
Sincerely Sindre
(3,203 Views)
To split the signals, use the Split Signals function.Smiley Wink
(3,197 Views)
Can i choose channel nr 1 in the split signal function?
(3,194 Views)
Of course. You can also use the Select Signals function.
You should have Context Help turned on and read what it says as you move your mouse over the functions on the palettes. You are asking very basic questions that you should know if you have taken any of the tutorials or just take a little time to read the documentation.
(3,187 Views)
