Calibration Executive
Why do the specifications differ between the Cal Exec calibration reports and the specs on NI's website? How where the calibration executive specifications determined?
(3,879 Views)
I can not look into this without knowing the following:
1.) What product are you using?
2.) Which specification isn't matching up and the calibration procedure that isn't working properly?
3.) What information are you comparing? Could you provide the documents that you are comparing?
Jim St
RF Product Support Engineer
(3,873 Views)
Do you know if NI has warranted specifictions for the Digitizer cards? For example, the PXI-5154 has 'typical' for the RMS noise, Rise/Fall Time, and Crosstalk specifications on the spec sheet. Are there warranted specifications anywhere?
(3,745 Views)
There aren't any warranted specifications available for our typical specs on digitizers.  It must be listed as warranted in the manual.
Jon S
(3,676 Views)
Jim,
Thanks for the response, however after looking at the specifications it seems that the calibraiton executive specifications are always tighter than the NI spec sheet, so even though they don't match we are okay as long as they are tighter specs.  Thanks
(3,672 Views)
