How can we achive simulataneous double buffered data acquition and wave form generation continuously on PCI 6115 and Visual C++
Hi all,
i want to use simulataneous double buffered data acquition and wave form generation continuously on PCI 6115 and Visual C++, how can we achive this when using API's like WFM_DB_Transfer,WFM_from_Disk etc,which waits until NI-DAQ finishes their respective operations.
in Example code 'while' loop is used,in that situation how can NI-DAQ perform simulatneous continuous i/p and o/p operations,is API's are not going to hold the Processor until they finish their tasks.is there any other way to achive this, please help me.
In my application, i am acquiring the data on 4 AI channels simulataneously and storing that data into a single file(using SCAN_to_Disk API).unlike this ,is there any way to store/get the acquired data on four channels or from single file to store in four seperate files?.
any help will be appreciated
regards
Reddy JS
(3,072 Views)
Hi Reddy, if you want to do simultaneous AI & AO operations, you will have to use asynchronous I/O functions like SCAN_Start, WFM_Group_Control, etc. You can't use the synchronous functions like Scan_to_Disk, WFM_Op and WFM_from_disk because, as you've noticed, they will not return to the caller until the operation is finished.
The NI-DAQ user manual has pretty good documentation for the sequence of function calls necessary to perform asynchronous I/O. You will make interleaved calls like SCAN_Setup, WFM_Group_Setup, WFM_Load, SCAN_Start, WFM_DB_HalfReady, DAQ_DB_HalfReady, DAQ_DB_Transfer, WFM_DB_Transfer, etc.
NI-DAQ ships with examples for doing double-buffered AI and double-buffered AO. (see DAQdoubleBuf.c and WFMdoubleBuf.c). You'll just need to combine these into a single program.
Good luck,
Joe
(3,070 Views)
Thanks Joe,
i am working on that, once i finish i will let u know.
Regards
Reddy JS
(3,051 Views)
