Wvfrm dig display occasionally displays "0.0"
I am acquiring data from multiple analog inputs in a while loop at 5 Hz. The acquisition is being timed by the loop. The data is being displayed on several waveform charts in this loop. I have the digital display for each input active. The value "O.O" randomly flashes on all digital readouts. The input data never drops to zero. The charts also do not drop to zero.
I'm sure there is a simple solution to this issue. Any suggestions?
(2,726 Views)
Hello Ira,
This is actually a known issue that will be fixed on the next version of LabVIEW. The workaround to this is wiring the data into a digital indicator along with the waveform chart and use that instead of the digital display.
Hope this helps, please let me know if you have any additional questions.
LA
(2,716 Views)
