‎07-03-2006 11:31 PM
‎07-05-2006 03:44 PM
‎07-05-2006 08:01 PM
Why do I need LabVIEW PDA?
In the documentation, it states that the functions can be accessed by C. I've just installed NI-DAQmx Base, and am writing a wrapper for the dll in VB.net.
If LabVIEW PDA was used, and dlls produced from it. I'll still need to write some interface to the dlls for accessing the data in VB.net.
‎07-06-2006
02:34 PM
- last edited on
‎07-14-2025
02:06 PM
by
Content Cleaner
Hello Mayu,
Accessing the CF-6004 on Pocket PC device with the NI-DAQmx Base driver can only be done with the LabVIEW API. The NI-DAQmx Base documentation states that the driver provides support for programming in LabVIEW or ANSI C on a Windows 2000/XP environment. However for accessing a PCMCIA, USB or CF data acquisition device on a Pocket PC 2003 mobile device, you can only use the LabVIEW API and this requires LabVIEW PDA 8.0.1.
For further explanation, take a look at the readme for the driver and Jesse's comments in this post.
I hope this helps,
Travis G.
Applications Engineering
www.ni.com/support
