How do I adjust the bounds of a square wave to be 0 to 5V rather than -5 to 5V?
When I run an example file that generates a squarewave, it has a control where I can select the max and min of the physical channel. However, when I change the min to zero and try to run the program, I get the following error, "Attempted writing analog data that is too large or too small."
(2,451 Views)
Nevermind, I found another example that has this option.
(2,451 Views)
