Home
Community
Discussion Forums
Most Active Hardware Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
how can I program an external trigger from a GPS, using C? I using the utility LxAiTriggerConf... Thanks
emma
Member
02-09-2004
04:02 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
Hi, I dont understand how to insert an external trigger in the PCI 6034E, Im using the input PFI0, but I dont know how to control it by software in c. Im using the function LxAiTriggerConf
Thank you
0
Kudos
Message
1
of 2
(2,517 Views)
Reply
Re: how can I program an external trigger from a GPS, using C? I using the utility LxAiTriggerConf... Thanks
Sean_C.
Active Participant
02-10-2004
05:24 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Hello Emma,
Thank you for contacting National Instruments.
The DAQmx C Reference Help has a pretty lengthy section on triggering. You can access this from:
Start >> Programs >> National Instruments >> NI-DAQ
I hope this helps.
Sean C.
Kudos
Message
2
of 2
(2,517 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
